Go Back   Land Rovers Only - Land Rover Forum
View Single Post
Old 05-14-2005, 08:46 PM   #5 (permalink)
LRWheelman
Default I forgot . . .
Also check the "rubber donut" rotoflex coupling @ the rear end where the rear driveshaft meets the pinion. Check all the u-joints appearance also. Look @ the front axle swivel balls for leaks. Look for leaks in the oil cooler lines. The 95 & 96 Discovery have many differences, so make sure you know which one you are looking @. 95's have 3.9 engines w/distributor, 96's have 4.0 w/o distributor. 95's have a code reader box under the passenger seat, 96's have OBD2. Manual trans. is a little rarer in 96's. Check to make sure they have the radio code, or hopefully the manuals and service records. Again, Good Luck, and Happy Hunting! LRW.
LRWheelman is offline   Reply With Quote
Google Links
