» Sponsors
» Sponsors
Old 07-05-2009, 04:35 PM   #1 (permalink)
Default 2.5 NAD fuel injector pump problem
I had a leak on an injector pipe but after disturbing it the thread is very poor on the pump side, I can get another injector pipe easy enough but I don't really want to replace the whole pump.
Is there a place where you can buy parts for the pump - ERC6761 - where the injector pipes connect there are 4 connecting peices that join to the main pump body via a banjo bolt, does anyone know if and where I can get some of these?
mal103 is offline   Reply With Quote
Old 07-06-2009, 08:20 AM   #2 (permalink)
antichrist's Avatar
You don't say where you are, which would help, but ring up a heavy truck repair shop and ask them who rebuilds their injection pumps, then give them a ring.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 07-07-2009, 04:59 AM   #3 (permalink)
antichrist's Avatar
What are the CAV numbers on the pump? I might be able to find you the part number of the fitting you need, in my CAV parts book.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 06:47 PM
Do 24 inch rims fit on a 2005 range rover hse? 05hse Wheels and Tires 178 07-29-2009 01:57 AM
94 Classic LWB fuel problem? mutator Range Rover Classic 10 01-07-2008 05:44 AM
Fuel delivery problem MuddyRangeRover Range Rover Classic 1 05-09-2007 12:44 PM
92 V8i (Dual Fuel) - How to replace the fuel pump? AND an LPG problem... Please help! chrismillard Discovery Series I 3 05-01-2006 06:39 PM
