Old 01-23-2005, 11:26 AM   #1 (permalink)
Default brake light blinks
could some one explain the blinking of the brake light on the dash board
I have been watching it blink for the last 10000 km - every thing seems ok
what is conected to that red light ? .
all but the best
rodney
rodney is offline   Reply With Quote
Old 01-23-2005, 12:09 PM   #2 (permalink)
Could be that you are low on brake fluid which means you either have a leak or your brakes are about worn out.
So go check your brake fluid level.
Mike J.
Old 01-23-2005, 12:30 PM   #3 (permalink)
And check the connections on the cap of the reservoir and that the cap is on properly.
worms is offline   Reply With Quote
Old 01-24-2005, 11:22 AM   #4 (permalink)
recently I replaced all the of the brake pads except the hand brake witch is pretty warn.
brake fluid level seems ok. I notice there are two cups with brake fluid, could the piping be slightly blocked?
has a load squeaking noise, when braking have any conection?
or is the light connected only to brake fluid level ?
rodney
Old 01-24-2005, 03:08 PM   #5 (permalink)
The line should only be connected to the master cylinder unless you are talking about the e-brake light flashing.
Exactly which light is flashing?
Mike J.
Old 01-28-2005, 10:48 AM   #6 (permalink)
its the B in brackes light. some times it doesn't flash at all & some times its on non stope.
I checked the car isn't haunted, some times I have my doubts.
Old 01-29-2005, 04:53 AM   #7 (permalink)
TerryS's Avatar
The Brake warning lamp on Defenders is illuminated by TWO things. 1) level switch in master cylinder. 2) E Brake switch, located behind rubber boot of E Brake lever.
If you visually confirm that the level in the master cylinder is OK, I can pretty much bet your E Brake switch has stuck, from debris behind the boot, or the single wire has chaffed where it goes through the seatbox from the harness, below.
Old 01-29-2005, 09:29 AM   #8 (permalink)
terry
could you be more specific (located behind rubber boot of E Brake lever) so I could locate and check the E brake switch.
thank's
rodney
