Old 03-05-2005, 09:20 AM   #1 (permalink)
Question buying '83 defender 110, what problems should i look for
I'm thinking of buying a 1983 defender 110, the first of the new shape i hear. Where are the main areas i should check for problems on it before i part with my hard earned cash?
Many thanks
furr_spangleball is offline   Reply With Quote
Old 03-06-2005, 01:44 AM   #2 (permalink)
New shape arrived in '81 at an 'A' reg in UK. Has the one you are looking at got the old vacuum diff switch, hi/low lever, four speed box and two-part doors? If it is also a V8, then you are looking at the very pinnacle of Land Rover development - downhill ever since! I am green with envy!
All the usual LR problems to look for at that age - chassis condition, bulkhead condition. Doors should be OK since there was nowhere for water to collect and anyway, split doors are cheaper to replace. Locks are bound to be knackered - I had four separate keys! Don't let the 4-speed box put you off, the range of ratios is almost the same as on a five-speed. Vacuum diff switch may not be working but is cheap and easy to fix - much easier to use and more reliable than the newer 'H' diff switch. Engine/gearbox/differentials need expert checking before purchase. A lot depends on the vehicle's history. Wish I had my old one from that era back, although I wouldn't be able to afford the petrol for the V8!
worms is offline   Reply With Quote
Old 03-06-2005, 02:04 AM   #3 (permalink)
1973 series 3 wagon retired
1981 series 3 stage 1 V8 retired
1996 Defender 130 current
Strazzman is offline   Reply With Quote
