Old 12-31-2006, 06:07 AM   #1 (permalink)
Default Can Anybody Help Please?
I have a Defender TD5 110 Hard top 2000. Two days ago I tried to fit a new stereo using the previous owners wiring loom. A fuse blew(under the drivers seat marked HAZ INT L.P RADIO) I replaced the fuse, stereo did not work. I checked the earth with voltmeter and earth in loom was not 'active'. I found a nearby wire (the earth wire from rear cabin light) I later realised this light took its live from the ignition. The stereo worked fine...but the engine did not start! I have ignition power but starter motor wont engage. After carefully studying TD5 electrical circuit diagram I live wired first the starter then later the output of the starter motor relay (which goes directly to starter). Both times the engine turned over but after 5 seconds seemed to have no fuel. Everything else seems to work fine. My best guess is that the ignition is buggered or that the ECM is fried. They would both explain the two problems I have. Can anybody offer any ideas, suggestions or advice as to what I can do to get moving again. If not it will have to be an expensive visit to Land Rover garage to get a diagnostics. Are there any tests I can do? Any help greatly appreciated!
ps happy new year
steve c is offline   Reply With Quote
Old 12-31-2006, 06:19 AM   #2 (permalink)
Originally Posted by steve c
I have a Defender TD5 110 Hard top 2000. Any help greatly appreciated!
ps happy new year
It sounds like the truck is done for. The only thing I can suggest is give the 110 to me and I'll put her out of her misery!
Bernard Mann
2004 Disco G4 (Sold to Josh Lester)
2005 Mercedes C230
2003 Disco S (Sold)
bernardmann is offline   Reply With Quote
Old 12-31-2006, 09:52 AM   #3 (permalink)
TerryS's Avatar
Do you know if you have an electrically operated shutoff solenoid on your Injection Pump? Check to see if you have voltage there.
