Old 10-22-2005, 04:47 AM   #1 (permalink)
xpower racer's Avatar
Default Coil Getting hot
Does anyone know if its ok for the ignition coil on my 2.5 petrol 90 to be getting hot . Its almost too hot to touch. I've noticed this while fault finding my indicator problem..
1985 Landrover 90 200TDi Disco engine, Disco rear axle, 2 inch lift and BLACK
Recovery Romanian style :-S http://www.youtube.com/xpowerracer yup...its me :-)
xpower racer is offline   Reply With Quote
Old 10-26-2005, 03:27 PM   #2 (permalink)
I guess no one knows.
But I was told buy someone the other day that they do get hot its just that most people have them under the bonnet so they never realise.
Old 10-26-2005, 04:41 PM   #3 (permalink)
4x4 Adventure Gear
John C's Avatar
It's pretty common. I had this problem with my RR. Sorry I can't be of more help.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 10-27-2005, 03:34 AM   #4 (permalink)
TerryS's Avatar
Marcus,
The Bosch coil, for whatever reason, seems to run hotter than the lucas coil, but even the Lucas coil runs hot. You should have a good look at your points (yeah, something the EFI people have forgotten) as they will run a higher rsesitance to ground if they are not maring up properly, or if they are partly burned.
A lot of people have opted to use a conventional coil (without the internal ballast resistor) and use an external ballast resistor.
Just the other week, I had a brand new Bosch coil puke it's guts out, all over the back end of my exhaust manifold. Engine wasn't running, but I was fault finding with the key on and the points were obviously closed.
Old 10-27-2005, 09:10 AM   #5 (permalink)
when you say "Puke its guts out" do you mean it exploded? With mine inside is there a posibility of it "puking its guts out" on my leg?
Having said that it is no more anyway. I'm picking it up on Saturday night and there wont be a coil in sight. The 200TDI engine will be sat in it
