Old 08-25-2005, 11:21 PM   #1 (permalink)
Unhappy D90 - GearBox/TransferBox Noise
I have a D90 with LT77 Gear Box & LT230 Transfer Box. I have a very unusual noise coming from either the gear box or the transfer box. This comes when in the high-end gears (ie: 3rd, 4th & 5th) at generally when accelerating in high speeds.
This has started some time ago, when I had/used couple of slightly worn rear tires. I immediately changed them & now they are all the same size.
Appreciate, if you could add any valuable thoughts.
Thanks,
Lasantha. (Colombo, Sri Lanka)
lmahagedera is offline   Reply With Quote
