» Sponsors
» Sponsors
Old 01-30-2009, 10:12 AM   #1 (permalink)
Default defender Brake Lights won't work
The master light switch on my wife's 2004 Defender 110 shorted out three weeks ago. Just before replacing the master light switch I also noticed that the brake lights did not work - I thought that there might be a link/connection. I replaced the master light switch and noticed that the brake lights still did not work. Today I took the brake light switch off my wife's Defender and put it on my 2004 Defender 90. The switch worked. I have have checked the bulbs and they appear to be good -does anyone have idea as to what is the problem? Is there any possible connection between replacing the master light switch and the break lights not working? Does anyone have any idea? Thanks in advance
burnhampm is offline   Reply With Quote
Old 01-30-2009, 12:20 PM   #2 (permalink)
antichrist's Avatar
Fuses?
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 01-30-2009, 01:34 PM   #3 (permalink)
Thanks but have checked fuze slot No 13 - fuse looks fine.
Old 02-01-2009, 12:49 AM   #4 (permalink)
boy do I feel stupid - after mulling over the problem, I finally took my voltmeter and stared checking the entire system to ensure that I had current running across the ignition switch, through the brake switch and then finally to the brake lights themselves. Long story made short - the problem all along was faulty light sockets.
Old 06-08-2009, 10:15 PM   #5 (permalink)
Reptile Expert
i have spare lights for sale if you need to replace them...
www.cardomain.com/ride/2650472/
www.fortmyersracing.net
www.cafepress.com/stolenheron
stolenheron is offline   Reply With Quote
Looking to Buy 98-02 Range Rover dantefr Range Rover P38, Mk III and Range Rover Sport 28 09-30-2008 04:59 PM
[D2] Service Intervals rmuller Tech & DIY 1 05-10-2007 10:11 PM
Where can I get... johnnybob06 Discovery Series II 7 02-21-2007 02:44 PM
Brake Squeal Discussion 01001010 Discovery Series I 4 11-08-2006 07:19 AM
How to hook up auxiliary lights? BIRD Discovery Series II 3 03-15-2005 10:04 AM
