» Sponsors
» Sponsors
Old 06-28-2009, 08:39 PM   #1 (permalink)
Default Defender Paint
I want to restore faded paint on a 94 Defender. What kind of paint is on this truck so I can select the correct products. Is it a two part (base coat - clear coat)? What products have others used with success?
arenter is offline   Reply With Quote
Old 06-29-2009, 08:22 AM   #2 (permalink)
TerryS's Avatar
base coat-clear coat is NOT two part paint. What's on your 90 is 3 part:
Base color-reducer-hardener.
there was no clear coat put on any of the '94 colors, just the later metalics (post '01)
Old 07-12-2009, 08:21 PM   #3 (permalink)
Thanks TerryS for the info, would the hardener respond to machine polish the way clear coat would? or do I need to seek out special products? I appreciate any insight you have on this.
Old 07-13-2009, 10:05 AM   #4 (permalink)
TerryS's Avatar
You can machine polish after about 2 weeks, given that you use a finest compound. I would recommend at least a month of curing time before any aggressive polishing. If you want a clear coat on top of the base coat, that's your choice, but if you do any amount of off-roading where scratches are likely, it is much easier to paint on top of a finish that does NOT have a clear coat on it.
Detailing 101: Common Question and Answers, What and Where to buy stuff + Technique David General Land Rover Discussion 55 04-30-2009 06:01 AM
Land Rover Defender 110 SVX earmarked for Australia Administrator Land Rover News 3 11-13-2008 07:05 PM
[ALL] Detailing FAQ's + Technique Disco Tech & DIY 0 01-08-2007 04:31 AM
British To The Core - The Land Rover Defender Serg General Land Rover Discussion 1 01-12-2006 11:57 PM
Fisish Restoration glenncof Range Rover Classic 2 04-15-2005 12:45 AM
