hi to everyone, i have a 1986 l/r 90 . when im on a motorway or bypass i have a lot of trouble holding it on a straight line i seem to be correcting the steering all the time ..particularly when towing my boat .. at times it wanders left +right fairly badly..
the swivels are fine everythings been polybushed, a frame ball joint replaced . no play in any joints.. i m suspecting the steering box ? ive taken any backlash out of it .. still the same problem.. do i just go for it +swop the steering box ? any ideas on how to tell for sure .. also how good is the defender steering on long motorway trips are they normally hard work to drive or is it mines so bad .. thanks glenn |
Is your trailer particularly tongue heavy? This will cause oversteer. Are your front tires properly inflated? Do you have sufficient swivel ball resistance?
Ok know this feeling, annoying ain't it!?!
Things to check, starting from the steering wheel; 2 UJs on the steering column Drop arm nut - they can come loose Drop arm ball joint to tie rod Tie rod ball joint to swivel Track rod ball joints (behind the axle) Panhard rod bushes - holds axle to chassis, the bushes wear. Radius arm bushes - 3 per arm Providing that all of these are A-OK then check the PAS box, even with the engine off if you turn the steering wheel you should feel/see the wheels turn. You'll need quietness for this - If you turn the steering wheel listen for clunks and knocks, you might be able to feel them too. Last night I did all of this on a mates defender and it ended up being the panhard rod bushes. Good luck.
1992 K-reg 200TDI Defender 90 (Eva) MSN - Geobloke@hotmail.com There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill |
thanks to every one for the help.. terry the trailer is ok.. ive towed it with a 4trak +no problems at all .. one thing i forgot to mention was the steering vagueness seems to get worse at about 60mph at 65 its quite scary at times ... looks like im gonna have to go through it all again ..grrrr ive checked everything in the past.. can any one tell me what the handling on motorways is like in a good defender are they normally hard work on long motorway trips? and thanks again to everyone much appreciated glenn
#7 (permalink) | |
The only time the steering has been "interesting" was when things like bushes, ball joints are worn.
I suppose a 90 might be a little bit more tiring over an extended period than a 110, but I have to say, steering is the least of the concern after 6 1/2 hrs on the highway, going between our place in CT and Maine. I have Corbeau seats, and they are fantastic, so my butt is no more numb than normal. What is hell is the baking my legs and feet take.
#9 (permalink) | |
Our 110 does tow better, but not much really.
#10 (permalink) | |
Series Moderator
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
