» Sponsors
» Sponsors
Old 12-23-2008, 08:43 AM   #1 (permalink)
Default Defender t/case stuck
I need Help, i have Defender 90 1997 V8 with 4.0 engine and A/T gear box, the problem is i cannot shift from High to low gear, i learned there is a switch on top of the t/case it could be locked, any idea?
ramisalh is offline   Reply With Quote
Old 12-30-2008, 11:41 PM   #2 (permalink)
Has it been a long time since you had the t-case in low? If it has been a long time, I would say that the shifter is siezed up where the pivots are at the base of the shifter under the floor on top of the trans/t-case assembly. Sometimes you can soak the mechinism in penitrating oil and free it up, other times the shift tower has to be removed and dissassembled out of the car to get the parts freed up. If you need a pic of the assembly out of the car, let me know.
Hope this helps.
Cheers,
Ben
Merz-Ben is offline   Reply With Quote
Land Rover Defender 110 SVX earmarked for Australia Administrator Land Rover News 3 11-13-2008 07:05 PM
Disco vs Defender FranzUgan Discovery Series I 1 12-11-2007 01:16 PM
New Defender out in March!!!! 300bhp/ton Defender 10 02-16-2007 07:47 AM
BUYER BEWARE;Re: Land Rover Defender 300 Tdi Turbodiesel (Best Defender Around) -$360 MG/WCB Land Rover Vehicles 2 07-01-2006 08:16 PM
British To The Core - The Land Rover Defender Serg General Land Rover Discussion 1 01-12-2006 11:57 PM
