Links
Old 12-19-2007, 07:05 AM   #1 (permalink)
Default dif lock light on dash flickers on and off
Can anybody offer me advise on the source of why my dif lock warning light on the dashboard keeps flickering on and off. Defender 300tdi with 150k. many thanks
andrew dunn is offline   Reply With Quote
Old 12-19-2007, 07:40 AM   #2 (permalink)
Searcaigh's Avatar
Gallery: 31
Switch or connection in the transfer case is buggered
Gordon T. Smith
Middle East Land Rover Nutter
Searcaigh is offline   Reply With Quote
Old 12-23-2007, 04:52 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
Most likely the wire going to the switch on the transfer case is shorting out. The plastic on the wriring goes brittle over the years and it does not take much to crack it and bear a wire.
p76rangie is online now   Reply With Quote
Old 12-25-2007, 09:20 PM   #4 (permalink)
is the diff lock engaged?
1973 series 3 wagon retired
1981 series 3 stage 1 V8 retired
1996 Defender 130 current
Strazzman is offline   Reply With Quote
Old 02-21-2008, 04:53 AM   #5 (permalink)
Life, love and Land Rovers
Blippie's Avatar
Switch is a likely candidate but not necessarily buggered - the diff lock switch can be adjusted, IIRC. If it's all gunged up or if "the newness has worn off" then this is a simple job.
Could be a connection or a bad earth.
Cheers
Blippie
Blippie is offline   Reply With Quote
