Old 01-04-2007, 09:55 AM   #1 (permalink)
Default engine cuts out on 110....HELP HELP HElp
i need help...as all i want to do is throw the car away......
i have been suffering an engine cut out problem on my 300tdi 110 (1996) for 6 months now and several LR mechanics plus loads of cash have not been able to help me identify the problem.
Problem is...the engine cuts out and will not start again for at least 10 minutes or so. It appears that the engine is not getting fuel. it always seems to cut out when the engine is warm, and (maybe) when the fuel tank is approx third full (still collecting data on this one)
so far i have changed the following.
fuel lift pump
immobiliser
fuel filter
solenoid
solenoid (terminal connector)
checked fuel lines and no sign of wear or air ingress
what would be the next step ? and, will the engine digagnostic box help identify the problem ?
could it be dirt in the fuel tank, and if so, how does one clean it out ?
would any other electrical systems cause the fuel switch to cut out ?
a bottle of fine italian wine from my local vineyard in italy for the magic answer........
andrew dunn is offline   Reply With Quote
Old 01-04-2007, 10:04 AM   #2 (permalink)
Banned
Take off the fuel cap and see if it starts.
Hank is offline   Reply With Quote
Old 01-04-2007, 10:24 AM   #3 (permalink)
there does not seem to be any vacuum forming in the tank, no suction noise etc.
Old 01-04-2007, 10:26 AM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
If you choose to throw it away.
I'll come and get it.
No need to fill your landfill up with that. I'll bring it to Oklahoma and throw it away here.
I feel it's my duty as a recycler.
I punch my clown daily.
Old 01-04-2007, 10:28 AM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
When our Mercedes was running like crap we replaced the glow plugs and regapped the valves.
She ran great after that.
Old 01-04-2007, 11:39 AM   #6 (permalink)
Thor's Avatar
Okie.... you're always trying to horn in on my official duty as a 110 recycler. I'm the only one licenced to drop in a 4.6..... I mean disassemble the 110 into a recyclable condition.
hahaha
Todd
Carpe Rangius Roverum
Old 01-04-2007, 12:33 PM   #7 (permalink)
I think its the Land Rover Spider - I had some problems where the vehicle (300Tdi 1996 130) would not start (not even turn over) on some occasions after a short run, however 10 minuites later would be fine, it did on one occasion stop running when driving home one day, just lost power a few times then stopped, would not start (as if wasn't getting any fuel but would turn over).
5 mins later it was fine, the next day a quick search - The Definitive Alarm Spider Post
In the defender its in a different place, in the battery box within a 3-4" square black box, with just one multicore cable entering - unbolt, drill or cut off anti tamper fastenings - remove spider, resolder worst of the joints
The next important step is go to the post office with the bottle of wine...
I'm almost certain this was my problem as in the last few months since sorting the dry joints it has not caused any problems...
wormhole is offline   Reply With Quote
Old 01-04-2007, 02:04 PM   #8 (permalink)
Or you could junk the smart spider and replace it with AMR4956 link lead and be done with.
buick215 is offline   Reply With Quote
Old 01-04-2007, 03:01 PM   #9 (permalink)
TerryS's Avatar
Betcha a salami it's air getting into the lines.
Old 01-04-2007, 07:07 PM   #10 (permalink)
Otherwise known as STEVE
I'd also suggest the air in the lines thang. Happens a LOT.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 01-20-2007, 10:52 AM   #11 (permalink)
hear i am back again,l still no resolve so the wine is nicley chillin hear in the 'not so snowy' italian dolomits. landrover still cutting out, happened twice yesterday after filling it up. air in the lines seems a good possability. any advice on how i check that or rectify it...is there any place where this tends to happen....fuel tank end, injectors ? id there a test i can do ?
cheers and grazie
Old 01-20-2007, 10:54 AM   #12 (permalink)
no idea what a spider is or what it looks like or even if i have one...what will removing it involve ? yesterday when i broke down, (just a part of daily landrover life) on a mountain hairpin in the dark in the alps)...i checked if there was current getting to the fuel pump solenoid (replaced two weeks ago) and there was current there,,,,is there any other 'spider' like controls which affect the fuel system...?
Old 02-23-2007, 06:24 PM   #13 (permalink)
Series Moderator
onslow's Avatar
cheers and grazie
insert a clear piece of hose in the fuel line if you see bubbles then you have air start in the tank to pump pipe then the pump to filter housing then filter to inj pump,
i once had a similar fault on a 2.25 diesel many years ago I couldnt find the source I removed the engine and replaced it with a petrol lump I replaced all fuel pipes except the one that screws into the fuel pump it was the damn olive on the pipe that wasnt sealing properly I spent hundreds on a fault that in th end would have cost pennies if i had found it sooner
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
