i need help...as all i want to do is throw the car away......
i have been suffering an engine cut out problem on my 300tdi 110 (1996) for 6 months now and several LR mechanics plus loads of cash have not been able to help me identify the problem. Problem is...the engine cuts out and will not start again for at least 10 minutes or so. It appears that the engine is not getting fuel. it always seems to cut out when the engine is warm, and (maybe) when the fuel tank is approx third full (still collecting data on this one) so far i have changed the following. fuel lift pump immobiliser fuel filter solenoid solenoid (terminal connector) checked fuel lines and no sign of wear or air ingress what would be the next step ? and, will the engine digagnostic box help identify the problem ? could it be dirt in the fuel tank, and if so, how does one clean it out ? would any other electrical systems cause the fuel switch to cut out ? a bottle of fine italian wine from my local vineyard in italy for the magic answer........ |
If you choose to throw it away.
I'll come and get it. No need to fill your landfill up with that. I'll bring it to Oklahoma and throw it away here. I feel it's my duty as a recycler. |
When our Mercedes was running like crap we replaced the glow plugs and regapped the valves.
She ran great after that. |
#6 (permalink) | |
hahaha
Todd Carpe Rangius Roverum |
#7 (permalink) | |
5 mins later it was fine, the next day a quick search - The Definitive Alarm Spider Post In the defender its in a different place, in the battery box within a 3-4" square black box, with just one multicore cable entering - unbolt, drill or cut off anti tamper fastenings - remove spider, resolder worst of the joints The next important step is go to the post office with the bottle of wine... I'm almost certain this was my problem as in the last few months since sorting the dry joints it has not caused any problems... |
#8 (permalink) | |
#10 (permalink) | |
Otherwise known as STEVE
#11 (permalink) | |
cheers and grazie |
#12 (permalink) | |
#13 (permalink) | |
Series Moderator
i once had a similar fault on a 2.25 diesel many years ago I couldnt find the source I removed the engine and replaced it with a petrol lump I replaced all fuel pipes except the one that screws into the fuel pump it was the damn olive on the pipe that wasnt sealing properly I spent hundreds on a fault that in th end would have cost pennies if i had found it sooner
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
