Hi
I have a 1987 defender that has a 200 TDI engine fitted.Your help and addvice is requested to a problem i have.I have aquired an old oil pressure gauge that would look the dogs bo***ks in my defender.Is it possible to fit this item and if so where can i find a suitable take off point for the gauge?I should add that the gauge is a old capillary type gauge!!!! Thanking you in anticipation Regards Alan |
Nothing is more reliable than the mechanical guages. Find the transducer for the electric guage and remove it and put your tube fitting in there. I lke the old Smiths butterfly water temp/oil pressure guages myself.
I dont have a gauge as such,Do you mean the oil light?If so where might the transducer be located,
Thank you Regards Alan PS What pressure do you think i should be getting. Last edited by alan90def : 12-10-2005 at 04:45 AM. |
Well, I guess if I had thought about I would have remembered that Defenders (except the NAS 110) don't come through with a pressure guage, elec or not. But, the pressure switch which extinguishes the light on your cluster is located at an output gallery of the oil pump, so that is still where you'll pick up the point to install the fitting for the tubing to the new guage. The oil pump on the V8 is external to the engine and easy to see the tappings, and a plug, when removed, gives you another tapping, but I'm not familiar with the TDi engines enough to know exactly where your pressure switch is located. That said, I'm thinking it's on the right hand side of theengine, down low and about the middle. There will be a single wire connected to the pressure switch.
I'm not sure which guage you dug up, but if you can find the butterfly Smiths, take the electric water temp guage out of your panel and replace it with the butterfly, Then you'll have both Oil Pressure, and Water temp, giving reliable info, right smack in front of your nose. |
I have found the pressure switch as you said on the right side.It is taken of the housing that holds the oil fillter,there is also another bolt that looks as if it is just blanking off.I will remove this and see if it will work from there.
Regards Alan |
