Old 04-04-2005, 02:18 PM   #1 (permalink)
Default Fuel cut-off solenoid
Had to stall the 200Tdi to get it to stop, so presumed the fuel cut-off solenoid had jammed open. Used to be easy to open and clean the solenoid on the early Tdis but once under the bonnet I couldn't find it on the bulkhead where it used to be. Am I right in assuming it is now built in to the injector pump? How easy is it to get at and clean/grease/replace? Haynes/LR manual and parts manual are all pretty hazy on this job and I've not found anything on this or other LR sites. Does this job never need doing?
worms is offline   Reply With Quote
Old 04-04-2005, 06:52 PM   #2 (permalink)
I just did mine on a 2.5NA, it was a simple job. Look for the wire going to the fuel injector pump, that should be the solonoid.
whistler110 is offline   Reply With Quote
