Links
Old 11-05-2007, 09:21 AM   #1 (permalink)
Default gear change thumping noise 300tdi transmission
I have been running my 110 defender 300tdi (1996) with a major thump coming from somewhere towards the rear underside everytime i change up in gear, especially when the engine is being worked. The transmission/engine have now done approx 150k miles. I have checked for play in bushes and replaced the suspension this year but fear i may have a worn transfer box or diff. What is the likely cause and treatment ?
andrew dunn is offline   Reply With Quote
Old 11-07-2007, 02:31 AM   #2 (permalink)
Default thumping noise
the noise could be transmission backlash caused by worn axle shafts and drive flanges. Take the shafts out and have a look at the splines and see how much free play you have between the drive flange and shafts, the LR original shafts and not very long lasting. A set of maxidrives could be all that is needed
1973 series 3 wagon retired
1981 series 3 stage 1 V8 retired
1996 Defender 130 current
Strazzman is offline   Reply With Quote
Old 11-07-2007, 02:47 AM   #3 (permalink)
Geobloke's Avatar
Whhhoooaa there!
Before you yank the shafts out check your rear prop shaft UJs, these are the usual suspects to clanks and clonks. You'll need to chock your wheels and take your hand brake off to test it. Get under the truck and give each UJ a good waggle. If there is play in the UJ you'll know it.
It could also be the A-frame ball joint as well.
UJs first though!
1992 K-reg 200TDI Defender 90 (Eva)
There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill
Geobloke is offline   Reply With Quote
Old 11-10-2007, 08:11 AM   #4 (permalink)
TerryS's Avatar
That's the most common source of clunking in a med/high milage truck.
