Old 10-28-2005, 07:53 AM   #1 (permalink)
Default Getting Hot
I was driving along enjoying the last of the nice weather with the top off last night and my temp guage started creeping up. I pulled over to check the usual things - coolant, oil, etc. and nothing looked out of the ordinary.
When I opened the coolant resevoir, it hissed like pressure had built up in there. Is that normal?
Any suggestions? Its my first Rover, so I am still a totally newbie when it comes to diagnosing these things.
I had the heat on, but that couldn't affect it could it?
Cheers.
-Christian-
'94 D90
www.ourownway.com
monkey catcher is offline   Reply With Quote
Old 10-28-2005, 08:39 AM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
How bad did it creep up....a dew degrees is not a big deal.. First i would check fluid level while cold, if it continues themostat would be next...
Old 10-28-2005, 08:48 AM   #3 (permalink)
Default Creeping
It got to about 3/4 of the way to the red. It usually sits at about 1/3.
-Christian-
'94 D90
www.ourownway.com
Old 10-28-2005, 08:49 AM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
When was the ladt time you had the cooling system flushed? if you haven't I'd do that...
Old 10-28-2005, 01:05 PM   #5 (permalink)
I will. Any other suggestions?
Oh, and how can you tell if a thermostat goes bad?
-Christian-
'94 D90
www.ourownway.com
Old 10-29-2005, 07:31 AM   #6 (permalink)
it overheats.
but first check it when its cold. You could have some leaks.
Old 10-29-2005, 07:05 PM   #7 (permalink)
Okay, did some research and it looks like a bad thermostat. I am going to change out the water pump while I am at it because it might as well have a new water pump, alternator and thermostat in the same month. Flush the system at the same time.
Quick test for the thermostat is to drop it in a pot of water and heat it up. The therm. should do its trick at the right temp. Seems like an awful PIA for a $16 part.
Brakes'll probably go next. I hope I get at least a couple of weeks of driving it before that happens because I'm miserable when its forced to sit there.
-Christian-
'94 D90
www.ourownway.com
Old 11-01-2005, 01:53 PM   #8 (permalink)
Default The answer
The answer to it all was a bad fan clutch. I am changing out the thermostat as a precaution. And as if that wasn't a big enough kick in the groin, there is a nail in my left rear tire (that's tyre for the Continental sorts).
When digging around, I found out that the previous owner did a great job installing the tail pipe, but left a nice hole in the central muffler, right on top where I couldn't see it without reaching up in there.
-Christian-
'94 D90
www.ourownway.com
