I was driving along enjoying the last of the nice weather with the top off last night and my temp guage started creeping up. I pulled over to check the usual things - coolant, oil, etc. and nothing looked out of the ordinary.
When I opened the coolant resevoir, it hissed like pressure had built up in there. Is that normal? Any suggestions? Its my first Rover, so I am still a totally newbie when it comes to diagnosing these things. I had the heat on, but that couldn't affect it could it? Cheers.
-Christian- '94 D90 www.ourownway.com |
Okay, did some research and it looks like a bad thermostat. I am going to change out the water pump while I am at it because it might as well have a new water pump, alternator and thermostat in the same month. Flush the system at the same time.
Quick test for the thermostat is to drop it in a pot of water and heat it up. The therm. should do its trick at the right temp. Seems like an awful PIA for a $16 part. Brakes'll probably go next. I hope I get at least a couple of weeks of driving it before that happens because I'm miserable when its forced to sit there.
The answer to it all was a bad fan clutch. I am changing out the thermostat as a precaution. And as if that wasn't a big enough kick in the groin, there is a nail in my left rear tire (that's tyre for the Continental sorts).
When digging around, I found out that the previous owner did a great job installing the tail pipe, but left a nice hole in the central muffler, right on top where I couldn't see it without reaching up in there.
