Old 05-05-2006, 12:15 PM   #1 (permalink)
Default Hot Exhaust
Just got a leak on the Y-Pipe welded up (again), and noticed that the exhaust was really running HOT. The coloration is almost purple, indicating that there's way to much heat coming out of the engine. Also, there seems to be just a hint of hesitation when you throttle up the gas. In the fall, I did a tune-up with plugs, wires, cap and rotor. Could there be a missfire in there despite the new parts? Could it be timing related? The engine temperature guage runs in the middle most of the time, but I did get it running about 3/4 last summer on the 95 degree and up days.
Drewfuss
'63 Series IIa: parabolic spring packs, 33x9.50 mud tires, Kodiak Heater, Fairey OD (SOLD)
'95 Jeep YJ: 8"lift (SOA), 35x12.50BFG Muds, Ford 8.8 rear w/detriot & disc brakes, 4.88 gears, warn8000i, daylighters......
'99 Jeep XJ: 3" Skyjacker, 31x10.50 MTR (SOLD)
'95 NAS D90 Wagon, front skid plate, brushguard, Hellas, 285/75 R16 Dunlop Mud Rovers, custom guages & dash
Drewfuss is offline   Reply With Quote
Old 05-05-2006, 12:51 PM   #2 (permalink)
Otherwise known as STEVE
too much heat would indicate it's running lean- REALLY unusual for a Rover. Maybe the timing is too advanced.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-05-2006, 02:28 PM   #3 (permalink)
TerryS's Avatar
It's more likely you're running too retarded, not to much advanced. The hesitation is a hint to that too. If it'a way retarded, like firing after TDC, you can wipe out your cats pretty quick. Manual reccomends about 8 dgrees BTDC, but I prefer 10-11 (except when I have to take it to emmissions inspection)
TerryS is online now   Reply With Quote
Old 05-09-2006, 09:49 AM   #4 (permalink)
Thanks for the info!! I think I'll change-out the fuel filter as well as check to see if there's any leaky vacuum lines. These are also things that I heard may have an effect on making the engine run lean. Regarding the timing, I figure I should check it out too as you all have suggested. Although, I've never made any adjustments to the timing since I've owned the vehicle, maybe the prior owner did.
Drewfuss
