Old 09-29-2006, 03:30 AM   #1 (permalink)
Default juddering 90
my 300 tdi 90 judders in 1st gear when cold but as engine warms up its ok i think their might be fluid getting on cluch but nothings leaking or any low fluids any ideas would be very helpfull
markie is offline   Reply With Quote
Old 09-29-2006, 03:49 AM   #2 (permalink)
TerryS's Avatar
Jerky clutch engagement, when starting off in 1st, is usually an indication of a scored, burned, or distorted flywheel face. This can come from excessive slippage, causing overheating, or, oil from a leaky real seal .
It's easy enough to have the flywheel refurfaced (machine a few thous off) when changing the clutch plate, but make sure you renew the rear seal at that time, if it seems oil related.
TerryS is online now   Reply With Quote
Old 09-29-2006, 04:00 AM   #3 (permalink)
Thanks I Think You Hit The Nail On The Head With That Answer
