» Sponsors
» Sponsors
Old 08-27-2009, 05:33 AM   #1 (permalink)
Default Lack of engine Power - 2005 110
Am having a problem with a lack of engine power. It seems as if the turbo is not working outside of 1st gear. A mechanic looked at it several weeks ago and told me that the turbo was "binding." I can hear it "spin up" at times but get no boost. I know it is not an injector problem. Have change the air filters and fuel filters. Does anyone have an idea as to what the problem is? I am starting to think it is a sensor problem and contemplating buying a code reader.
additional information - this afternoon I switched out the ambient air pressure and temperature sensor. this does not appear to have any impact on the problem.
more information - this morning I switched out the MAF sensor and there was no improvement. I unplugged the MAF sensor and there was a noticeable improvement but it still seemed to lack power going uphill.
Any thoughts would be greatly welcomed.
burnhampm is offline   Reply With Quote
Old 10-09-2009, 10:45 PM   #2 (permalink)
Well, this is a couple of months late, but I haven't been on here in a while. I had a similar problem with my '00 TD5 D90 and it had EGR system problems, I think the EGR valve was staying open all of the time if I remember correctly. At any rate, I replaced the vacuum accuator to the EGR valve and it fixed my issues.
Cheers,
Ben
Merz-Ben is offline   Reply With Quote
Help! Check Engine Light Comes On & Engine Always Loses Power After Hitting Pot Hole! Jungle Man Discovery Series II 7 09-10-2009 08:50 AM
tapping in the engine sean6079 Discovery Series II 8 07-20-2009 07:53 PM
P38 2.5 engine replacement non-starter help! george_ni Range Rover P38, Mk III and Range Rover Sport 0 07-19-2008 06:07 AM
NYTimes: Is 8 Enough? Transmissions Meet the Need for Speeds Adam in NYC USA General Land Rover Discussion 6 09-16-2006 09:21 AM
stalling and lack of power discohunter Discovery Series I 9 09-05-2006 12:06 PM
