» Sponsors
» Sponsors
Old 01-23-2009, 08:45 AM   #1 (permalink)
Default location of brake light switch
Have a 2004 110 TD5, i just replaced the master light switch - no problems. Now brake lights don't work. Can anyone tell me where the brake light switch is? I have the workshop manual but cannot figure out where switch is located.
burnhampm is offline   Reply With Quote
Old 01-23-2009, 10:57 AM   #2 (permalink)
TerryS's Avatar
On the pedalbox, behind the booster
Old 01-23-2009, 01:30 PM   #3 (permalink)
thanks - sorry for the additional question but do I need to take of the "skid" plate under defender to get to the peddle box?
Old 01-23-2009, 07:46 PM   #4 (permalink)
TerryS's Avatar
No, The pedal box is attached to the bulkhead, above the footwell where your pedals go up and through to the engine compartment. Lift the bonnet, and over on the right side you'll see your brake master cylinder. It is mounted to the brake booster (like a big black doughnut. The booster is attached to the front of the pedal box. Thats where you'll find the brake light switch, with two wires attached.
Old 01-24-2009, 03:54 AM   #5 (permalink)
thanks, really do appreciate the help -the work manual was not all that clear
brake light switch or fuse??? daniels disco Range Rover Classic 6 11-28-2008 01:54 PM
Stuck in park luckesc4vett Discovery Series I 7 06-08-2008 12:41 AM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 05:45 PM
How hard to swap out the Brake Light switch? Adam in NYC USA Discovery Series I 2 01-31-2006 05:58 AM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 10:06 PM
