Old 06-06-2005, 12:48 PM   #1 (permalink)
TerryS's Avatar
Default Mechanical Water Temp Gauge Installation
I was asked, yesterday, at the local British Car day event in CT about installing a mechanical water temp guage on a Rover V8 engine. I did this on my Defender, but it would be the same for Range Rover classic, and 3.9 Disco.
Without looking at the intake manifold on my son's XD, I couldn't say for certain that it will work on 4.0 Discos and Rangies, or 4.6 engines, as I don't have their intake manifold so indellibly burned into my brain.
Any way, If you take a look at your intake manifold, in the front, right corner, you will see where the electric water temp guage sender is tapped into the manifold, horizontally. Above it is a flat boss, with nothing there. That is where I drilled and tapped a 3/8" FPT hole, into the same pocket in which the electric sender is mounted. Most aftermarket mechanical guages come with adapters for installing their capillary tube sender, usually in 1/4", 3/8" and 1/2" MPT. The half inch adapter is just borderline too big, so the 3/8" was just right. I did this when I had the manifold off, set up on the Bridgeport miller, but if you're carefull, it can be done in situ.
Old 06-06-2005, 12:56 PM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
Hey Terry,
Can I bring my manifold over and have it drilled?
Too bad I didn't know about the British card day, I would've loved to have attended. Oh well, maybe next time.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 06-06-2005, 03:59 PM   #3 (permalink)
TerryS's Avatar
Yes, I'll be happy to do it, and yes, it's too bad. It was held at Harkness Mem. Park, in Waterford, literally a stones throw from the waters edge. You could just hear all that British Iron quaking in fear of a salt air breeze.
Between my son and I, I think we own 20 or more cameras. Do you think either one of us Dumasses would think to bring one?
