new defender owner needs starting problem information
Just posted my first thread below, the one about obd scanners.
I thought though that someone might be able to short cut my diagnosis though before I chose and buy a scanner.
Truck - 1995 Defender 3.9 USA delivery
Conditions:
New fuel filter, clean fuel, fine battery, runs very well in general
Symptom:
Two out of five times, when I try to start the engine, instead of lighting right off, the engine just spins. Repeated attempts MIGHT make the engine start, but the other day I had to push it off to the side from a gas pump. I had given up on a restart but tried "one more time" and the engine fired up like a champ.
Engine temperature and/or recent/non-recent use does not seem to be a factor.
I thought that it might be a fuel pressure bleed down issue, but repeated turning of the key from off to run doesn't seem to help. I thought that it might if the lift pump as going bad, but as I say, it doesn't seem to make a difference.
Thanks in advance for any suggestions that you might make.
Jack
