1. I take it if a D90 is a hard-top then it is difficult if not impossible to change it into a convertible?
2. Is it possible/practical/economical to convert a 5-speed into an automatic. Thanks guys Regards MJH |
On the contrary, it is very easy to remove the top of a hard top, or SW. Only tricky part is that you have to remove the rear door, and replace it with a tailgate. (in itself, also very easy to do, except that they don't give them away) You'd probably also want split doors instead of one piece doors.
Changing a 5 speed over to an auto box is easier than vice versa, but requires a different bellhousing, torque converter (usually would come with a secondhand ZF auto)flywheel gets changed to a flexplate, and console, shifter mechanism, and autobox tunnel would be required (the console isn't but it would look hokey without it) You would then just have to remove the clutch pedal box. Whether it's paractical or not depends largely on what you want to use it for, and how handy you are. Paying someone to do it might get a bit pricey, and might be offset by just buying a soft top '97 D90 Last edited by TerryS : 03-17-2007 at 09:12 AM. |
#4 (permalink) | |
Of course, if I ever decide to convert to an auto this is probably exactly what I'll do. ![]()
Trigger VP Austin Chapter - Texas Rovers SCARR 08 (South Central Area Rover Rally)- April 17th - April 20th, 2008 |
#5 (permalink) | |
#6 (permalink) | |
The Best 4X4XFar
Also what year of Defender. In short it's real easy to convert from hard top to soft top or truck cab. Going soft top is real easy as Land Rover used to sell Full Tilt 90's and the NAS spec one with the Bikini style top. All you'd need is the frame and jocky sticks and the canvas. Simply unbolt the hard top, break the seal and lift off. 2 people could have it done in no time. The only real issue is the central bulk head, NAS spec Defenders are different to most others accept late UK models. Going to a truck cap would be interesting. As for going auto, well lots of places here in the UK would do the work. It's quite simple just use an auto from a Range Rover or Discovery, it'll mostly bolt up and work. If you don't want to end up with the shifter on the floor however you'll need to fab up a higher centre consol/transmission tunnel.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#7 (permalink) | ||
Oh yes.. there will be blood.
http://www.d-90.com/mod/sw2st/index.htm As Terri suggested and which I would agree, if you really want a soft top, I would look into simply buying one rather than spending all the money on the parts and then paying someone to do all the work. Quote:
Chris von C. Sick of how slow LRO has become with all the ad's? Rage Against The Banners!! If you use Firefox, install the add-on AdBlock Plus. All ads gone and the site loads like greased lightning again. |
im in NYC and intend to buy a 1997 NAS. Ill just hold out for an automatic with a soft-top. Thanks for the advice. Last question: What do I look for when I go and look at them? I intend to bring any one I intend on buying to a LR dealer for a critical look. ....unless anyone has other suggestions. the ones that fit the bill so far are in new england and in nj/penn.
