Hi all
I have recently bought a 110 2.5 td, I had the vehicle checked when I bought it and all seemed in order, the breather hose isn't connected to the air intake etc, but I was told this is quite normal for an oldish td to "breathe" a little. My main concern is that after driving for a while, if I stop at trafic lights or a junction the oil pressure light comes on when the engine revs return to an idle. If I apply just a little more throttle, then the oil pressure light goes off. I was wondering how serious is this, and am I likley to kill the engine by driving it around, or is it a smaller problem. Being that it's the oil pressure light I would of thought it could be a bit more serious. The oil level is normal and if the engine has been switched off for an hour or so the problem appears to reset, ie you need to drive around again for a while for the problem to show. Any ideas, help with diagnosing the problem would be most helpful. Alex |
MISSING THE HELL OUT OF SEATTLE
I Had The Exact Prob With A 2.5 D That I Had. It Is Normal At Low Rev's Or At Idle.same As The Alternator Light Going On In A Series When The Idle Speed Drops. Had The Injectors Gone Through And That Helped A Bit.the Timing Of The Engine Helped As Well. Not A Colosial Issue I Dont Think. Good Luck
82' series III 109 safari prepared 2.25 pet.WILL NEVER GET RID OF!!!!!! 91'Range Rover classic 3.9L V8!(sold) 98' Land Rover Discovery with a MOD wolf 300 tdi(sold) 97' Defender 90 300 tdi (sold) 99' p38 Range 4.6 autobiography (sold) 2007 Porsche GT3..faster than the 109! |
Many thanks for the reply s3 guy, nice to get a bit of extra reassurance, I've done an oil change and that appears to of improved the oil pressure warning for now, I've also since bought a manual and it's noted in there that this happens with engines with relativley high mileages.
#4 (permalink) | |
