Old 12-20-2006, 06:50 PM   #1 (permalink)
Rebhun109's Avatar
Default Replacement Diff housing Cover
Has anyone ever replaced there diff housing covers? Mine is severly damaged and has had a hole blown through the metal. I was wondering how difficult it was to cut off the old, and weld on a new one. What is the axel made of steel, or iron? Any help would be good.
79 109 SW
73 109 XMOD FFR
94 D90
Rebhun109 is offline   Reply With Quote
Old 12-20-2006, 07:25 PM   #2 (permalink)
KevinNY's Avatar
Any welding place can patch it for you. Replacement Pans are also available or you could sewer cap it.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is offline   Reply With Quote
Old 12-21-2006, 06:33 PM   #3 (permalink)
antichrist's Avatar
I've welded them, but it's really thin metal and takes some bit of skill.
For a stock rover diff you can replace it with an 8" schedule 10 (or schedule 40) steel weld on pipe cap. You'll have to drill and tap it for a filler plug, and grind out a bit on the inside for the ring gear. But you won't need a diff cover anymore. If it's the front you'll need to get a different panard rod, one that goes up and across above the diff.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
antichrist is online now   Reply With Quote
Old 12-26-2006, 10:34 AM   #4 (permalink)
Series Moderator
onslow's Avatar
you can buy them quite cheaply from the UK takes a few hours to do but dont weld the old one up it will leak again believe me I know
