Links
Old 09-08-2004, 06:00 AM   #1 (permalink)
Default Squeaking back windows
The back windows that slides open squeaks. The rubbers seems to be old. Any idea on how to stop the squeaking.
gjja is offline   Reply With Quote
Old 09-09-2004, 09:06 AM   #2 (permalink)
lrmaniac's Avatar
Hi
well, I replaced all the rubbers, and the squeeze came again
THen the lock was loose, I believed that that was the problem, and fixed it, but the squeeze came again and the lock is loose again.
So now my Td5 has almost 5 years and the only way that I could stop the sueeze was to place a small piece of rubber between the glasses!
If you find what else can we do..........................
Thank you
Joao Pedro
Defender 90 Td5; 1966 88"SIIA
lrmaniac is offline   Reply With Quote
Old 09-09-2004, 09:50 AM   #3 (permalink)
My landrover is a 1998 variant and the windows at the back don't squeak (well i never heard them) however that's probably because I have the radio up full blast
squeaks are normally caused by something binding and tight
not loose which would cause Rattling
have you manually slid them back and forth to find if they bind anywere???
siggy is offline   Reply With Quote
