Old 04-24-2006, 07:19 PM   #1 (permalink)
130CC's Avatar
Default Tensioner Pulley
So I found I had a small tick tick click type of noise coming from the engine bay this morning I am thinking that it might be from the aux belt tensioner any other things that i might need to check before I have to go to a mechanic.
TD5 Engine 110,000 on the clock.
Thanks Adam
" In rivers and bad government the lightest things flow to the top" Johnny Cash
Old 04-25-2006, 12:29 PM   #2 (permalink)
WineryRover's Avatar
Thanks Adam
I think you hit it right on. Had the same thing last year and it was the aux belt tensioner pully that was cracked. Simple fix for an ugly noise, once they actually sent the right part!
'06 LR3 SE7
'94 D90 #115
'72 Series III 88
WineryRover is offline   Reply With Quote
Old 04-25-2006, 04:37 PM   #3 (permalink)
130CC's Avatar
Yeah Managed to have a look last night and yep so much dirt and rubbish in the bearing it was running rough as guts. Just need to order the right part now.
Adam
Old 04-25-2006, 08:31 PM   #4 (permalink)
Otherwise known as STEVE
I'm putting one on mine tomorrow... common problem.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 04-28-2006, 04:27 PM   #5 (permalink)
130CC's Avatar
I have to say it's a bit rough what LR charge for the replacement part glad I went to a bearing shop after getting a price from the dealer. They were able to split the pulley replace the bearing but it back together for $10 while LR wanted to replace the entire belt tensioner assembly they were unable to replace just the pulley. Is there a part number for just the pulley or is it true they only replace the entire thing?
Adam
