Old 12-28-2005, 10:17 AM   #1 (permalink)
Default ticking sound in dash
A ticking sound just started this morning somewhere inside the dash in my 90. It sounds similar to the turn signal, but isn't. I was running the wipers at the time. The ticking continued after turning off the ignition.
What gives? Any help from you braniacs would be most appreciated.
Thx.
GriffSC is offline   Reply With Quote
Old 12-28-2005, 01:23 PM   #2 (permalink)
TerryS's Avatar
Pull off the panel over your fuses and see if it's coming from one of the relays. It may be the wiper timer relay, which gets a feedback from the park switch in the wiper motor.
Old 12-28-2005, 02:09 PM   #3 (permalink)
thanks, terry. the ticking actually stopped, but i've got a problem with the switch for my rear wiper anyway (it's sticking), so i'm gonna have to open it up anyway.
Old 12-28-2005, 03:19 PM   #4 (permalink)
ish
ish's Avatar
Griff......did you find out what it was????? curious.
"Ish...I have in the past mistaken you for a perverted shit bag...now I realise that I am not shit bag enough. You truly are a king among men.I am not worthy with such imagination."
Series 3 Guy
2005 Range Rover HSE
2007 BMW X3 M Sport Pkg
1990 911 Cabrio triple black
2006 Mini Cooper S Checkmate - GONE
1987 Corvette - 18 yrs Gone,,, sniff sniff -
ish is offline   Reply With Quote
Old 12-28-2005, 03:41 PM   #5 (permalink)
why, did you plant a bomb in there?
i'm gonna check it out tonight if i can get to it. at least it stopped for now.
Old 12-29-2005, 02:13 PM   #6 (permalink)
Default Other wiper question
Is there a way to set the rotation range on wipers? I rarely use them, but I noticed that last time I did, the driver's side came in for a bit of a rough landing as it returned to the bottom of the windshield on every stroke. I am worried that the constant battering will damage the wiper or the weather stripping at the bottom of the windshield.
Thanks.
-Christian-
'94 D90
www.ourownway.com
monkey catcher is offline   Reply With Quote
Old 12-29-2005, 02:29 PM   #7 (permalink)
TerryS's Avatar
Wet your windshield, turn them on and shut off the ign when the wipers get to the top of the stroke. Get out, take off the wiper arm, and push it back on the post so that the blade is just touching the edge of the windshield (top,side of frame) If they over-run on top and bottom of stroke, it generally means that your quadrant gear, and likely, the cable too, are worn, so that ther is slop in the mesh between the quadrant and cable. It's a couple hour job and some medium dash dissassembly.
Old 12-29-2005, 08:36 PM   #8 (permalink)
ish
ish's Avatar
WEEEEELLLLL.... the truth is i've been having a little QC problem with my fuse mechanisms..........If I don't hear from you I'll just assume the issue worked itself out.......
Series 3 Guy
Old 12-30-2005, 10:14 AM   #9 (permalink)
well, those fuses were fine after all... at least the ticking stopped.
Old 12-30-2005, 03:58 PM   #10 (permalink)
Art Vigil's Avatar
Griff, I can't offer a solution, but my first D90 did the exact same thing once in a while. I never did figure out why, but (other than being a bit annoying) it never caused any problems.
If you do find out what causes it, I'd love to hear about it.
Regards,
Art Vigil
Denver City, CO USA
'95 RRC SWB TWR Edition
'72 Series III 88" (Rita)
'97 D90SW #2426 (sold 3/05)
'95 D90ST #2620 (sold 10/01)
Art Vigil is offline   Reply With Quote
Old 01-02-2006, 03:10 AM   #11 (permalink)
Damn, the bomb didn't go off, now I will have to do it again!
1973 series 3 wagon retired
1981 series 3 stage 1 V8 retired
1996 Defender 130 current
Strazzman is offline   Reply With Quote
