Old 09-17-2007, 03:48 AM   #1 (permalink)
Default Turbo whistle
Hi, my 300 Tdi 90 has suddenly developed a high pitched whistle/whine which seems to be turbo related. It starts at the point that the turbo cuts in and the pitch increases as more power comes through. The fault was not present one day but started the following day. What I'm trying to say is, it didn't seem to gradually develop. I had to make a 200 mile trip in it yesterday and it started after a mile or so, but didn't get any worse, in fact it had decreased a little by the time I got home. Has anyone got any ideas what it might be? I did think it might be a split in one of the rubber turbo pipes, but I can't see anything wrong with them. Does this suggest that the turbo os goosed?
keith organ is offline   Reply With Quote
Old 10-16-2007, 07:46 AM   #2 (permalink)
It does sound like a split in a hose or something similiar. I also had this problem when I hadn't tightened the downpipe bolts to the turbo correctly (easy fix!). Have you lost any power etc? Check all the connections are tight and inspect for holes/splits (Usually tiny, hence the whistle) Does anything rub on any of the pipes?
Simon
bigfatsi is offline   Reply With Quote
Old 10-16-2007, 07:59 AM   #3 (permalink)
Geobloke's Avatar
As above!
Also, by chance did you have the vents open or the passenger window?
When I fitted my snorkel I got a marked increase in turbo noise, also funnily enough when I replaced the centre mid boxes of the exhaust system.
When a turbo goes you know about it! Either it dissintergrate making a hellofa noise or if the bearings go you'll get oil being pumped in to the exhaust system and the whole world will be lost behind you in a cloud of smoke!
1992 K-reg 200TDI Defender 90 (Eva)
There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill
Geobloke is offline   Reply With Quote
Old 10-16-2007, 10:10 AM   #4 (permalink)
2004 Discovery II driver
check the seals on the turbo down pipe and intake. I dont drive a TDI, nor have i had a turbo but I have had a lot of experience with boosted applications (i.e. I street raced a v6 centrifugal supercharged mustangs for 2 years). Make sure all the pipes are properly fitted and not cracked, any air or exhaust leak can cause a whistle. I blew my s/c once, trust me, you know when that thing goes, your turbo should be fine.
stolenheron is offline   Reply With Quote
Old 10-25-2007, 06:35 PM   #5 (permalink)
Ben
TN-LR3's Avatar
my I6 cummins diesel has a shitload of turbo whistle, most diesels do. I do have a 62mm turbo though and cold air intake with a 4' downpipe
It's what diesels do, along with giant clouds of smoke that make people think twice about riding your ass
1997 D-90 #1345- Bunch of stuff
1992 RRC LSE- for sale/ maybe crawler project
2002 Dodge ram 2500CTD- dd/tow rig
TN-LR3 is offline   Reply With Quote
