Links
Old 02-02-2007, 06:22 PM   #1 (permalink)
Default Two 110's which one? Buying monday
Hi all, new to defenders and have the choice of these two at the moment.
85 wagon.
Body Good
3.9 isuzu turbo japanese import.
New front + rear diff locks(maxi drive)
Recon gearbox+transfer+centerdiff
4-speed
320,000ks
$13,000au
needs a bit of cosmetic work in and out(paint panel)
It rides well, plenty of power and noise from the 3.9
97 Dualcab
body excelent
Stockstandard
320,000ks
Original motor
$15,000au
Im leaning towards the 3.9 is this a reasonable price?
They seem like a big mechano set and im wondering what parts are interchangable from '85 to the current models.Also the is the 4-speed box better than the 5-speed for Strength, the bloke selling the '85 told me this.
Thanks people
Rich
Riverrat is offline   Reply With Quote
Old 02-03-2007, 04:36 AM   #2 (permalink)
TerryS's Avatar
What is the 'original motor' in the '95
LT95 boxes (4sp) are strong, but parts are getting very hard to source.
Yes, they are like Meccanos, almost all body parts are interchangable.
Both sound nice, toss up to me.
Old 02-03-2007, 05:09 AM   #3 (permalink)
Its a 2.5 turbo diesel, Thats all i know
Old 02-04-2007, 05:58 AM   #4 (permalink)
jozg44's Avatar
If its a 1997 vehicle that should be a 300Tdi- no problems there. Just check that the cambelt has been changed regularly (90,000 km should be the change interval). Some have head-gasket problems if they're allowed to overheat- check for lack of power, white smoke from the exhaust, low water level in the header tank, and sometimes a 'ticking' from the back of the engine.
Jack
1990 Ninety County Station Wagon Diesel Turbo
http://members.lycos.co.uk/threelandrovers
jozg44 is offline   Reply With Quote
Old 02-05-2007, 05:32 AM   #5 (permalink)
Heroes in a half shell....Turtle Power
WCURoverD90's Avatar
Gallery: 10
Get the 1997.....
"All those that believe in Telekinesis, Raise my hand'
"If I wanted a Hummer, I would call your girlfriend"
Rovers
97 Defender 90 Soft Top
2005 LR3 HSE
1956 Series 1 107 Tow Truck
WCURoverD90 is offline   Reply With Quote
Old 02-05-2007, 07:45 AM   #6 (permalink)
TerryS's Avatar
Bells & Whistles on the older one make it sound appealing, but you need to know who did the work, and because of those mods, how was it used?
200K miles is a lot of miles, and despite Dualcabs(especially with a tilt) are somewhat impractical, the fact that it's 14 model years newer for the same money says your money would be better put on it, rather than someone elses 'project' truck.
Old 02-05-2007, 08:02 AM   #7 (permalink)
Gallery: 10
Some very good points.....I can't see why the older one is almost as expensive as the 97.....
Rovers
2005 LR3 HSE
Old 04-17-2007, 12:50 PM   #8 (permalink)
the Izuzu motor is really good but the fack that the rest of the truck is so old means that everything else is probly warn out. Especially if the truck has lockers and off road gear that means its been thrashed. go 97 and then mod it.
CliftonRover is offline   Reply With Quote
