Old 10-17-2006, 09:11 AM   #1 (permalink)
Default tyre pressures
any one know the correct tyre pressure for b f goodrich all terrain 265/75 r16 on a 110 double used mainly on the road
markie is offline   Reply With Quote
Old 10-17-2006, 09:15 AM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
Do the chalk test to make sure.... but I believe it is 35 p.s.i. I have 235 85 and I do 40 rear 38 front!
Old 10-17-2006, 09:20 AM   #3 (permalink)
cheers i will try that as i have them at 30 psi front and 36 psi rear and they seem a bit flattish
Old 01-16-2007, 04:04 PM   #4 (permalink)
1999 Defender 110 Extreme with expedition pack and other goodies.
If they are LT construction you can run them at higher pressures that that, which I would recommend you do on long trips, as it reduces tyre flex and heat build up. When I am fully loaded I have 48 back 42 front, and run 42/42 most other times on road.
MHRead is offline   Reply With Quote
Old 01-16-2007, 07:15 PM   #5 (permalink)
Super Moderator
Disco's Avatar
I find that 40 psi all round is perfect.
