Old 09-03-2006, 06:05 AM   #1 (permalink)
TREX
Thumbs down Wacko Tacho
Ok, i have a tacho i want to fit to my 2000 Defender 130. It has 5 wires 2 for lighting 1 power 1 ground and 1 sense line (i think). However i am only used to hooking up tacho's that run of tacho generators (aircraft) or actual fixed line drives (tractors). so if anyone can help me on where to run the sense line to or if it would have a line installed already and would just need un stowing, or is this just simply not possible? any help would be most appreciated.
Cheers
Trex
TREX is offline   Reply With Quote
Old 09-03-2006, 01:58 PM   #2 (permalink)
TerryS's Avatar
what make tach is it? If it is used, what did it come off of?
Some take their pulse from the negative side of the coil, Land Rover tachs take an impulse from one corner of the three phase line. (off the alternator)
Old 09-03-2006, 04:34 PM   #3 (permalink)
The MoFab Man
-MOSES-'s Avatar
If you have a coil, it goes on the negative post. On a gems model I have no Idea ??
http://www.MoFab.org
Are you gonna pass that ??
99' D1
55' S1 86" RHD SW
00' RR 4.6 HSE
My Favorites:
http://www.texasrovers.com/
http://pikespeakrovers.com/
http://oeminstock.com/
http://greatbasinrovers.com/
http://MyRover.net/
Yep, thats my truck in the avatar....
-MOSES- is offline   Reply With Quote
Old 09-03-2006, 09:41 PM   #4 (permalink)
Magicly Delicious
Bene's Avatar
is it a diesel?
Kevin
1994 Discovery
Old 09-04-2006, 03:42 AM   #5 (permalink)
TREX
Thumbs up cheers
Thanx for the tips fella's i'll take a look at the wiring diagrams and see how i go. Any idea how to calibrate it though? or do i need to take it into the shop on a dyno or similiar? and what do you mean is it a diesel? can you get petrol 130's? not here in australia anyway.
Old 09-04-2006, 08:53 AM   #6 (permalink)
Geobloke's Avatar
Question
Ah ha you no doubt have a TD5 if you are in OZ! This is Lowetensions Tacho instructions for fitment to a TD5
I have a 200TDi and this very tacho and run it off of the "W-Terminal" on my alternator. Works a treat and handy when it sits next to a boost gauge!
1992 K-reg 200TDI Defender 90 (Eva)
There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill
Geobloke is offline   Reply With Quote
