Links
Old 08-24-2004, 02:53 PM   #1 (permalink)
How do I wire around an electrical problem in the brakelights in my Defender 90?
I suggest you run a switched lead straight from the battery into a toggle, and then to the rear lights. Each time you stop, just flick the switch and viola! You've got brakelights too - this could be in the Defender section, and also doubled in a DIY format. Great!
steelbreakfast is offline   Reply With Quote
Old 08-24-2004, 03:02 PM   #2 (permalink)
beer drinking member
dent's Avatar
steel, sounds like a guy i knew where the turn signal relay was hosed and he just keep flicking the turn signal up and down to make it flash
Serg, was thinking like a seperate section where ppl would not have to try and search for the topics constantly... sorted like forum under the forum... was thinking of questions that frequently come up. ie: obd codes, reset service engine light, how to change your brakes, etc
on another note... great site serg
dent is offline   Reply With Quote
Old 08-24-2004, 04:20 PM   #3 (permalink)
viola
I thought that was a flower!
If you put a manual switch it will be a traffic violation. If you decide to do an emergency stop in traffic and the car at back runs into you because you forgot to flick the switch? Oh dear.
Repair/change the original switch or fix the fault. It's only a single circuit.
Alan H is offline   Reply With Quote
Old 08-26-2004, 03:55 AM   #4 (permalink)
130CC's Avatar
Default Follow the white Rabbit
This is a shortend version of the May 2002 Defender Electrical Library.
Fuse 13 of the pasanger fuse box (provides an ignition feed) to the brake pedal switch on a GO wire (Green, Orange),
the brake pedal switch is a normaly open switch, (push the pedal close the circuit make lights go) this allows current to pass allong a GP wire (Green, Purple) to feed on a d90 the LH brake lamp,RH brake lamp, Centre high mounted stop light and the trailer socket.
it's a simple circuit to trace give it a go.
If you have any questions just ask.
Hope this helps in some way.
Old 08-30-2004, 02:52 AM   #5 (permalink)
Muttley's Avatar
Angry
This is really NOT a recommended fix Sort it properly!
if you need to bodge the circuit to get you going then take a lead direct from the battery pos terminal into the brake light switch (take a look under the dash at the top of the brake pedal armature) then direct to the lamps, do not rely on a manual switch. If this doesnt work then it is the brake light switch that is at fault and replace it.
Muttley
Scottish Peasant
My landy is WAY faster than yours!
Muttley is offline   Reply With Quote
