03 Freelander Heater Blower Problem - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 01-14-2010, 04:00 AM Thread Starter
Quoted: 0 Post(s)
Hello....anyone Out There Can Point Me In The Right Direction For This Problem? The Heater Blower Fan Was A Little Problematic A Few Months Ago Where It Was Whiny And Had A Zing To It That Came And Went. It Got Quieter Over Time But As Of Recently It Seems Like The Motor Seems To Be "bogging" Down. If You Put It On 4 The High Setting It Is Alot Slower Than That Or It Will Blow At The Speed For About 30 Seconds Slowly Putter Out. Let It Sit For A While And It Will Do The Same Thing. Is There Any Kind Of Relay That Would Be Causing This Or Is It Just The Blower Itself? I Was Curious As I Had The Coolant Leak Problem In This Vehicle From The Heater Core, Which I Had Repaired And Was Wondering If Leaking Coolant Over Time Fouled The Blower Motor. Any Information Would Be Greatly Appreciated.
biker833 is offline
post #2 of 4 (permalink) Old 01-16-2010, 02:42 AM
Quoted: 0 Post(s)
There is a blower motor resistor pack on the heater box near the firewall just above the blower motor. Disconnect the wiring clip undo 2 screws, pull the pack out. It should have 3 exposed resistor coils. Possibly they are clogged up with dried/encrusted coolant. I've just replace a new heater core too... a time consumig job. You should however be able to remove the blower motor and/or the resistor pack with out removing the facia or heater unit, just a bit awkward negotiating clutch and brake pedals.
Philsch is offline
post #3 of 4 (permalink) Old 01-18-2010, 03:55 AM Thread Starter
Quoted: 0 Post(s)
philsch..thanks for the reply. My mechanic had about 13 hours into replacing the heater core. Glad to hear this may not be as time consuming if it turns out to be the problem.
biker833 is offline
post #4 of 4 (permalink) Old 01-20-2010, 03:11 AM
Former LR tech, Albany NY
Quoted: 0 Post(s)
13 hours WTF?
Warrantee times went town to 2.0 and customer pay was 3.6. Boy you got robbed by an idiot without directions.
I used to work on Rovers. Got a question just ask, need a Rover looked at, Albany, New York.
Rovin4life is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Heater Blower problem win32 Freelander / LR2 0 05-08-2009 04:12 AM
Heater/Blower motor? angelfire_Discos Discovery Series II 5 02-26-2009 04:12 AM
99 D11 ac/heater blower motor problem jabsaw Discovery Series II 5 05-03-2008 04:05 PM
AC/Heater Blower DiscoDoggII Discovery Series II 6 06-27-2007 05:18 PM
need help w/ heater blower motor Frank Range Rover Classic 10 03-05-2006 01:49 PM
You may post new threads
You may post replies
