Old 11-06-2005, 11:01 AM   #1 (permalink)
td4
Unhappy 03 fuel filter
Can any one find the fuel filter on a 03 td4.
I've bought a new one from landrover Its a cylinder shape with a pipe connection at either end. It this the right one??????.
td4 is offline   Reply With Quote
Old 11-08-2005, 03:47 AM   #2 (permalink)
Hi
Check the part number, it should be WJN000080, like you say its an aluminium cylinder with connections either end. Its located underside of car towards the rear on the drivers side sill/wheel arch, its covered by a plastic box which hides the actual filter, its not visable until the cover is removed.
Hope this helps
Cheers
Steve
scubaboy is offline   Reply With Quote
Old 11-23-2005, 10:19 AM   #3 (permalink)
Originally Posted by scubaboy
Hi
Hope this helps
Cheers
Steve
How do you get the filter out of the case ? My fuel filter is hidden below the engine management system and looks impossible to remove easily. We did speak to a chap at Cavendish Motors in Chesterfield (Neil is very knowledgeable as they only deal in landrover parts etc) and was advised that the fuel filters are not changed regularly, usually at the 60,000 mile service or so.
susyhutch is offline   Reply With Quote
Old 11-23-2005, 01:12 PM   #4 (permalink)
td4
Default fuel filter removal
Is your lanrover a around a 03 plate td4 if so it should be behind a plastic cover by the drivers side rear wheel arch.
It not an easy job to change. even after removing the cover it is still inside an plastic sleve held in by two clips,even after removing the clips its still a very tight fit in the sleve.
took me at least an hour to change.
Regards
td4.
