Old 11-12-2005, 10:27 AM   #1 (permalink)
Default 1.8EXi lift kit and snorkel
Im after doing a few mods and would like to know if you know of any places on the web were i can get a snorkel for a freelander,and is there any breather pipes that may need venting, also im after a 2" raise but ive been told there are two types, would anyone be a ble to spread any light on this?
Thanks
happymagik is offline   Reply With Quote
Old 11-12-2005, 12:42 PM   #2 (permalink)
http://www.pangaea-expeditions.com/p...prodindex.html
google is your friend. well for snorkels, but the rear ends and transfer cases dont have breathers.
Old 11-12-2005, 02:52 PM   #3 (permalink)
Otherwise known as STEVE
There are two ways to lift your Freelander. One is with Ironman springs- 1.5" lift but not being a "true" lift since the range of motion is still stock. All it does is raise the ride height without improving or changing the articulation.
Second would be the DAP/Bearmach lift kit. This moves the entire strut assembly down away from the body 2". It's been proven to be a better lift than the spring lift in off-road testing.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 11-12-2005, 04:02 PM   #4 (permalink)
HMBFreelander's Avatar
Thanks
DAP Inc (http://www.dap-inc.com) makes a 2" spacer lift. I't easy to install and not too expensive. They also list a snorkel in their on-line catalog.
The other choice for a lift is Ironman Suspensions in Australia (http://www.ironmansuspension.com/). They offer a set of replacement springs that provide about 1.5 inches lift in addition to a bit stiffer ride and better cornering. They are a bit harder to install and also a bit more expensive considering shipping to the US.
If you want to see what you are getting into there are installation articles for both at:
http://www.freelanderliving.com/stor...jectFreelander
The springs coupled with taller tires Is what I have on mine. Which is best? That's a never ending discussion. I chose the springs because I thought they would be a bit easier on the CV joints and I was able to get them used from someone de-moding his truck for trade-in.
Moding is addictive - have fun!
Brian
2002 Freelander SE
HMBFreelander is offline   Reply With Quote
Old 11-12-2005, 04:04 PM   #5 (permalink)
Smile
thanks for the advice, as i will be doing the work myself will the DAB lift be harder than the other to get sorted and does the DAB lift involve new shock/springs etc. Also are there any other breather pipes i should keep an eye on when traveling through water?
Old 11-12-2005, 04:05 PM   #6 (permalink)
speaking of CV joints we have had alot of problems with them. basically a low speed vibration around 25 to thirty in the pedal and foot well area. The inners go bad and knock around causing the vibration.
Old 11-12-2005, 04:14 PM   #7 (permalink)
The rear diff has a breather - it's a small tube that terminates on the front side of the tool well/sub-woofer enclosure. In my off-road configuration it's about 24 inches off the ground.
There is a similar "toy breather" on the front end too - I remember seeing it- but I don't know what it vents.
The main concern in wading deeper than the LR recommended limit (16" on a stock truck) is getting mud and water in the bell housing and wiping out the rear main seal. That's happened to more than a few Freelanders.
Brian
2002 Freelander SE
