2003 Freelander KV6 2.5 blown head gasket repair - Page 3 - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-11-2012, 03:29 PM   #31 (permalink)
I had to fabricate exhaust manifold gaskets
dgHUN is offline   Reply With Quote
Old 11-11-2012, 03:30 PM   #32 (permalink)
Cleaned the head
Old 11-11-2012, 03:32 PM   #33 (permalink)
Every bolt was rusty and a challenge to take apart
Old 11-11-2012, 03:33 PM   #34 (permalink)
And finally the rear head is back on
Old 11-11-2012, 03:37 PM   #35 (permalink)
Next step will be to torque the head bolts.
I´m reusing the bolts, did not want to spend $150 on new ones.
25Nm steps are done, only the 180 degree turns are waiting for me.
Hopefully it will work out.
Old 11-18-2012, 02:51 PM   #36 (permalink)
Both heads are back and torqued down.
I did the 25Nm steps and 90 degree in one round and another 90 degree in the second.
I felt it went to easily and I did another 45 degree on all the bolts. I hope it will hold down the head for a while.
Old 11-18-2012, 02:55 PM   #37 (permalink)
Homemade J-something tool to lock the tensioner, basically a nail
Old 11-18-2012, 02:56 PM   #38 (permalink)
Transferring marks from old to new timing belt
Old 11-18-2012, 03:00 PM   #39 (permalink)
Tool to turn camshafts, homemade, aluminum plate with two bolts
Crankshaft and front head are on mark and locked.
Rear head on marks
Last step, water pump hooked up
Effort = 2 hours to figure out steps, tools.
Old 11-18-2012, 03:07 PM   #40 (permalink)
I could turn the crankshaft around, looks like timing isn't messed up.
I'm fighting now with the front exhaust manifold. Somehow the engine moved up and down, back and forth, I just couldn't put on the manifold to the bolts.
Old 11-19-2012, 05:07 PM   #41 (permalink)
Today's progress...
While putting back the oil pan, I dropped the screw that hid in a black hole on the engine.
Old 11-19-2012, 05:09 PM   #42 (permalink)
The engine is so much off, I couldn't put it back on the mount. I will need a cherry picker here.
Old 11-19-2012, 05:09 PM   #43 (permalink)
Old 11-21-2012, 10:55 AM   #44 (permalink)
Cherry Picker and bolted up exhaust manifold.
Old 11-23-2012, 01:14 PM   #45 (permalink)
I had one exhaust bolt fell down and hid on top of the oil sump.
Found it when I didn't need it anymore.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
2002 Freelander 2.5L - Blown Head Gasket? redwing30 Freelander / LR2 1 12-26-2009 05:06 PM
do i have a blown head gasket? roggle Discovery Series II 12 06-10-2009 08:54 PM
Blown head gasket?? sailtom Discovery Series I 0 09-02-2007 10:50 AM
blown head gasket tirehoss Discovery Series II 5 07-11-2007 05:15 PM
freelander kv6 exhaust gasket super set on e-bay raid13 Land Rover Parts and Accessories 0 05-05-2007 08:07 PM
SEO by vBSEO 3.3.2
