2004 Freelander with trouble codes: P0174, P1472, P1471, P1775, and P0705 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 20 (permalink) Old 06-09-2010, 05:34 PM Thread Starter
Quoted: 0 Post(s)
I would really like to know what is going on with my Freelander anyone who has some info for me would be absolutely great!
The other day the DOWNHILL ASSIST WARNING light came on and when I turned off my car then turned it back on it was gone, but as I was driving for a little more the SERVICE ENGINE SOON light came on
I ran a code scan and these are the ones that showed up:
P0174: System to lean (Bank 2)
P0705: Trans Range Sensor Circuit Malfunction (PRNDL Input)
For the following codes it said: "DTC definition not found", but I did some research and it looks like the codes mean the following:
P1472: VIS power/butterfly valves always open?
P1471: VIS balance motor valve always closed?
P1775: Gearbox fault?
If anyone has any info that could help me that would be greatly appreciated!
Thanks
FreelanderDan is offline
post #2 of 20 (permalink) Old 06-09-2010, 05:46 PM
Former LR tech, Albany NY
Quoted: 0 Post(s)
look at the lean code first. look for something broken like a pcv hose. if nothing is broken then smoke test it to see a leak. if no leaks then look at a maf sensor.
Did you get the fuel pump recall done yet?
I used to work on Rovers. Got a question just ask, need a Rover looked at, Albany, New York.
Rovin4life is offline
post #3 of 20 (permalink) Old 06-09-2010, 05:54 PM Thread Starter
Quoted: 0 Post(s)
Yes I did get the fuel pump recall done
post #4 of 20 (permalink) Old 06-10-2010, 07:36 AM Thread Starter
Quoted: 0 Post(s)
Where is the pcv hose and how would I do a smoke test on it? And where is the maf sensor?
post #5 of 20 (permalink) Old 06-10-2010, 08:19 PM
Site Sponsor
Quoted: 0 Post(s)
Hose looks like this:
http://bputah.com/FRP/Land_Rover_Fre..._LLH500220.jpg
MAFS is located between air filter housing and air intake manifold
bpUtah is offline
post #6 of 20 (permalink) Old 06-11-2010, 07:32 AM Thread Starter
Quoted: 0 Post(s)
Thanks for the pic, where is that hose located?
post #7 of 20 (permalink) Old 08-19-2011, 09:42 PM
Quoted: 0 Post(s)
getting the same codes did you get it fixed and how?
mine is a 2002 freelander was there a fuelpump recall?
snowtn3 is offline
post #8 of 20 (permalink) Old 08-23-2011, 09:24 AM
Quoted: 0 Post(s)
Regarding the P1471 and 1472 codes, I believe those were the same codes on mine, requiring replacement of the entire intake manifold assembly.
Good luck,
Julian
03 Disco
04 Freelander
72 Series III
71 RHD Hillman Super Imp
65 MGB
73 MGB-GT
knac1234 is offline
post #9 of 20 (permalink) Old 08-03-2012, 06:28 AM
Quoted: 0 Post(s)
I am having a similar problem:
We have a 2005 V6. It started running very poorly last week. The power just dropped off and now it idles very poorly and sometimes just stalls completely. It cannot be driven.
I pulled the following codes:
P0171
P1471
P0305
I replaced both VIS motors and it still runs like crap. Can you provide any suggestions?
Satchmo3 is offline
post #10 of 20 (permalink) Old 05-19-2013, 03:01 PM
Quoted: 0 Post(s)
Question Misfire and Lean. Any Suggestions?
I have a similar problem, only mines is when you floor it.
I bought the car about 2 month ago and its been in the garage and engine has been rebuild. I'm stuck on this misfire codes that keeps popping up.
P1471, P1472, P0300, P0301, P0302, P0303, P0304, P0305
Under normal driving up to 70 mph it would run smooth and no codes will pop up. It's when you floor it at any speed even from stand still, that the check engine light pops up when the rpm reaches around 6000. The car lags all the way up to the 6000 rpm point and misfire randomly until you stop and restart the car. After restart it'll run smooth again like usual.
I have done:
spark plugs, wires, and all coil
have open up both VIS, cleaned, soldered and resealed
checked hose, manifold (exhaust and intake) for leaks
checked and cleaned MAF
brand new timing belts(front and rears), accessory belt, air filter from when rebuild
refilled transmission fluid and front differential gear
checked all injectors with noid light(haven't bench flow test)
check for sparks at all plug wires (ok)
I'm pretty much stuck and it's still doing the same thing. I might be able to come up with some more tested on more of the electrical but for right now bumbed out. Anyone have any suggestions on what else to look for, it'll be a big help and greatly appreciated.
I will keep post on the status of this problem until it gets squared out.
LGREF9 is offline
post #11 of 20 (permalink) Old 07-31-2013, 09:47 PM
Quoted: 0 Post(s)
Smile Mines Broken Too!
I'm having the same issues LGREF9, except no as many misfire codes...have you found a solution?
I haven't had the fuel pump recall yet and i'm hoping that will fix my issues. I reeeaaaally don't want to replace the Upper Intake Manifold, that will leave me broke.
Thanks!
chimchase is offline
post #12 of 20 (permalink) Old 08-01-2013, 04:55 AM
Quoted: 0 Post(s)
Sorry chase nope haven't figure out what's causing it. I'm just driving it carefully so that it doesn't misfires on me and it hasn't been acting up lately except once on the highway when I floored it to switch lanes. I'm suspecting both or one of the VIS motor might be fried and going to do some test this weekend. I remember some oil getting in there when I first opened them. I'll probably forget to post back up here my results but I have subscribe to get email notification so remember to remind me so I can help out if I did find a solution.
LGREF9 is offline
post #13 of 20 (permalink) Old 10-23-2013, 09:19 AM
Quoted: 0 Post(s)
Good luck,
Julian
was the intake replaced under warranty. was told warranty is under Federal Emissions Act up to 80000 mi.
Fred d is offline
post #14 of 20 (permalink) Old 10-27-2013, 12:35 PM
Quoted: 0 Post(s)
codes
removed mass flow sensor and found liquid (oil like ) no smell in intake hose. any suggestion to why liquid in hose
Fred d is offline
post #15 of 20 (permalink) Old 11-27-2014, 03:56 PM
Quoted: 0 Post(s)
Cool
Fear Not, my mechanic says Landrover Engineer says that it is normal to see small amount of oil in the MSF boot.
IrishFreelander is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
still have p0171/p0174 codes........ raleighcrx Discovery Series II 1 05-19-2010 07:43 PM
trouble codes rovercrazy Discovery Series I 4 05-15-2010 06:17 PM
Trouble codes - what should I do? BlackSVT Discovery Series II 7 03-13-2009 10:37 AM
codes P0150&P0174 armydisco Discovery Series II 7 02-17-2008 08:32 PM
New Trouble Codes Ryan Roundy Discovery Series I 7 02-13-2006 12:04 AM
You may post new threads
You may post replies
