Links
Old 08-18-2005, 04:24 AM   #1 (permalink)
Default 235/70/16 In my TD4...Was it a good ideia?
I've just purchased tyres with those charactheristics for my Freelander.
I'm really happy with the looks and feel of it, I haven't tried it off road yet
I thought I read somewhere that 235 would be fine with the original alloys, and actually I just saw it was 225.
As anyone tried this size of tire with the original equipment? Is it just fine or it might rub in curves or with heavy loading/off-road ?
VanAlex is offline   Reply With Quote
Old 08-25-2005, 07:00 PM   #2 (permalink)
HMBFreelander's Avatar
The main issue with tyres that wide is interference with the spring perch - both front and rear - something you should have noticed by now! You can easily feel the clearance between spring perch and tyre with your hand. I can't get my fingers between there with my 225X75-16 MTRs on Honda Pilot rims.
The diameter of the 235X70-16s is about 29 inches which is between the 225X70-16 (28.4) and the 225X75-16 (29.3) so you may be OK under most conditions. But, you should expect some rubbing with it loaded heavy or when stuffing a wheel off-road.
Good luck!
Brian
HMBFreelander is offline   Reply With Quote
