Old 03-10-2006, 12:19 AM   #1 (permalink)
Default 52 plate 5drFreelander leaking Roof
Just wondering if you can help
I got in my freelander this morning to find that waster was dripping from the light in the overhead set. The drops where steady and still evident after driving for an hour.
I have removed the light cover only to find a fair amount of water came out
Andrew
tedshred is offline   Reply With Quote
Old 03-10-2006, 12:44 AM   #2 (permalink)
Andrew
** Forgot to add that I have just fitted roof rails** but there is no visable water in the holes**
Old 03-10-2006, 10:45 AM   #3 (permalink)
I think the water goes in from the antenna.
Hippo is offline   Reply With Quote
Old 03-10-2006, 02:03 PM   #4 (permalink)
Otherwise known as STEVE
No visible water in the holes because it probably drained down into the car.
I've had leaks at the antenna and at the bolts where the roof rails mount. Either is a real possibility.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 03-11-2006, 08:27 AM   #5 (permalink)
do you have a sunroof.
Old 04-13-2006, 04:50 AM   #6 (permalink)
thanks finally managed to sort it
when I put the roof rails on the dodnt get a good seal
Andrew
