Old 05-08-2006, 02:26 PM   #1 (permalink)
Blk_Ronin's Avatar
Default Air Conditioning
Has anyone else had this problem...
Got a 2004 Freelander 2.5 V6...
Over the weekend, the air conditioning unit just stopped working...
In fact it's blowing hot air. Took it to the dealer today, and they can't say what's wrong with it. Actually, they indicated that there aren't faults when running a diagnostic, and that they can't get to re-charge it because it's not taking a charge.
No of this makes sense to me, so just wondering if any of you had a similar problem... And were you able to get it fixed?
Ronin
Blk_Ronin is offline   Reply With Quote
Old 05-08-2006, 07:05 PM   #2 (permalink)
could be blockage in the system. if they couldn't recharge it then there is something wrong.
With my experience with AC it could be any number of things. On Freelanders we don't see AC problems at all. Only time I ever saw something bad on a freelander AC was a truck that got struck by lightning.
AC in rovers is pretty bulletproof.
We rarely see it unless its an old one.
Old 05-08-2006, 08:30 PM   #3 (permalink)
You say it is blowing hot air - this is from the heater not the A/C. The heater will always override the A/C - it is a good way to defog the car on a cold night - heater and A/c on, the net result is not luke warm air but hot air.
So you may not actually have a A/C problem at all but the heater is simply stuck on.
Garry
garrycol is offline   Reply With Quote
Old 05-08-2006, 08:35 PM   #4 (permalink)
Otherwise known as STEVE
struck by lightning? Holy crap... LOL! I'd be glad ANYTHING worked after that.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-10-2006, 01:31 PM   #5 (permalink)
Blk_Ronin's Avatar
Hi Garrycol,
What would cause the heater to override the A/C...
Kevin
Old 05-11-2006, 01:20 AM   #6 (permalink)
Originally Posted by Blk_Ronin
Hi Garrycol,
Kevin
The heater is simply stronger than the A/c. That is with the airconditioner on full, the heater is strong enough to heat the airconditioned (cool) air. The air in most cars passes through both the heater core and the A/c or at least has a mixing arrangement - depends which core is switched on to get heat or cold - as I said if they are both on (full) you will get hot air, not cold air or slightly warm air. This applies to most cars - try it with another car without climate control (I don't think V6s have climate control - if so you need to look at the control mechanism) - put the A/C and Heater on full and go for a drive - you will find that hot air comes out, however because it has been also through the A/C the air is dehumidified so works as a great demister.
As I said in my earlier post - an A/C does not make hot air - so if you have hot air coming out of your vents then the heater must be on.
The only exception would be if the A/C was somehow working in reverse (like a household reverse cycle airconditioner/heat pump) but I don't believe this is possible in a car.
You need to see what is making the heat first - most likely the heater - stop the heat then sort out the A/C if needed.
Cheers
Garry
Old 05-12-2006, 12:02 PM   #7 (permalink)
Blk_Ronin's Avatar
Actually there has been an interesting turn of events...
The repair guys said the air conditioner clutch has burnt out, and that I'd need to get a new one... They haven't advised yet whether its covered by the warranty.
Old 05-13-2006, 09:03 AM   #8 (permalink)
Should be,
If you are out of Freon then you shouldn't have cold air, now depending on the outside temp then that will be the temp of the air coming out so if it was hot then by all means it feels like hot air.
Thats how all AC systems work.
but when the clutch is bad there is freon just no ability to circulate it.
Old 05-13-2006, 09:06 AM   #9 (permalink)
And the vehicle that was struck by lightning had every single module toasted but no wiring problems. It went along the CAN bus wire and thru the entire system. Blew out the AC too.
The guy was driving and it just got hit by lightning.
