Old 11-25-2005, 04:42 AM   #1 (permalink)
Default Buying a Freelander
I'm looking to join the Freelander club! Have wanted one for a while and seen a 2000 1.8 Xi. Checking the net for owners comments there seems to be major problems with earlier petrol engines, head gaskets going etc. Does anyone know if this is an earlier model? What years are affected? Any advise would be greatly appreciated. Ta.
Architect is offline   Reply With Quote
Old 11-25-2005, 05:18 AM   #2 (permalink)
Hi
What sort of mileage and Stealer (shit, i mean Dealer!) History has the vehicle got? Where are you from ? If you can Private Message me with the vin details and check out the history for you.
Just be carefull with high mileage vehicles with little or no service history.
Hope this helps
Steve
scubaboy is offline   Reply With Quote
Old 11-25-2005, 07:04 AM   #3 (permalink)
Thanks for your comments - Mileage is 54,000, local car dealer - owner is friend of my inlaws. Has a service history but don't know VIN number yet.
Old 11-25-2005, 07:09 AM   #4 (permalink)
Electrical Prob's Man
If it's a 1.8 STAY AWAY.
It will fail eventually, find a TD4 or V6 much better reliability
16 VALVES...
OH, IS THAT ALL???
FREELANDER V6
Trev150 is offline   Reply With Quote
Old 11-25-2005, 07:30 AM   #5 (permalink)
I certainly would at least spend some money on getting the head gasket changed as a matter of course, it may seem a waste of cash but believe me it isnt, i've a 1999 1.8 in at the moment with about the same mileage needing a new engine due to overheating/head gasket problems, also maybe worth checking the temp sender and gauge and having it replaced, it was another reason the cars were having problems. Owner/drivers werent aware of overheating problems because of dodgy gauges, although i'm pretty sure this was a very very early problem with them.
Like Trev says, go for a TD4 or V6 if possible.
Get back to me asap with the Vin and i'll check if its had any warranty work done on it.
Cheers
Old 11-25-2005, 07:47 AM   #6 (permalink)
Can you check this on all models? any where in the world?
16 VALVES...
OH, IS THAT ALL???
FREELANDER V6
Old 11-25-2005, 08:30 AM   #7 (permalink)
Yep
Old 03-20-2006, 04:18 AM   #8 (permalink)
Default be warned
do not bye 98" or 99" there is major problems with engine block (cracking) be warned do not bye. you will be sorry! you are best of with a td4.
david watkiss is offline   Reply With Quote
