Links
Old 07-15-2005, 07:17 AM   #1 (permalink)
Default Clunking in drivetrain
Hi I hope someone can help.
I have a 2001 Freelander 2.0 Dsl which has recently developed a heavy Clunking noise in the tunnel when accelerating.
This noise is worse in 4th or 5th gear but can be heard through all gears.
Any advice much appreciated
Morgan is offline   Reply With Quote
Old 07-15-2005, 05:47 PM   #2 (permalink)
I am not sure on this one but check the front rear diff rubber mount - give the diff a good up and down shake. I have had the knocks on changing down and it was the diff mounting. The front of the diff is supported by only one which is off to one side - it often fails - it wears out in the center.
Relatively easy to check so why not.
Garry
garrycol is offline   Reply With Quote
