» Sponsors
» Sponsors
Old 08-20-2009, 08:01 AM   #1 (permalink)
Default Coolant / Oil Change
Can almost any Oil Change service (business) work on the 02 Freelander? Obviously I don't want to go to the dealer.
Can you go to a parts store and buy coolant if you need to top it off?
EDIT: I researched this a bit and found you can get the coolant at a NAPA store, for one example. I got the list of approved oil in the owner's manual. Doesn't look too difficult to have someone change. Pretty standard types. Assuming correct?
KickingLettuce is offline   Reply With Quote
Old 08-21-2009, 08:15 AM   #2 (permalink)
Well, I went to an oil service place and they did it. So that answered my question.
The next question was it was still $90! not much cheaper than the dealer.
IS it recommended to change your own oil?
Old 08-24-2009, 12:26 PM   #3 (permalink)
Default Changing your own oil
Hi,
it is quite cheaper to change your own oil, however if there is ever a problem releating to the oil you can always go back to the oil change place....now, having said that, it may be an uphill battle to get anything out of them, but at least you can try, otherwise if it's your mistake, it your problem! Since we have a vehicle that not "on the rack" most places will let you bring your own filter...so you do end up saving a little.
Smaguns is offline   Reply With Quote
How do I change the coolant CORRECTLY? WLADiscoII99 Discovery Series II 9 08-11-2009 05:30 PM
New to the group Disco II SE 67k 6600 CheyneRover Discovery Series II 4 08-11-2009 01:40 PM
Best way to change green coolant to Dexcool shpreetzer Discovery Series II 13 07-20-2009 07:19 PM
Coolant hose rupture JimN Discovery Series II 5 12-05-2008 01:46 AM
coolant flush and refill. wtf. Jupiter Rover Discovery Series II 8 05-04-2008 09:57 PM
