» Sponsors
» Sponsors
Old 12-30-2008, 01:25 AM   #1 (permalink)
Default easy way to change the oil
Hi
I'm new with Freelander (2001), please any one to tell me in which side to look for the drain to change the engine oil? Do I have to remove the (protection bottom gaurd) to find it?
Thanks
jim196 is offline   Reply With Quote
Old 01-01-2009, 02:46 PM   #2 (permalink)
Originally Posted by jim196 View Post
Hi
Thanks
Its easy to change. I have an 02 Freelander. The filter is in front of the passenger front wheel. You can get these at most parts stores. The drain plug is easily accessed without removal of the protection guards. Takes about 7-8 qts.
dabbler is offline   Reply With Quote
Old 01-01-2009, 03:17 PM   #3 (permalink)
Deployed OIF
ArmyRover's Avatar
Welcome aboard you two.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 01-03-2009, 06:58 PM   #4 (permalink)
2002 Freebie's Avatar
Any recommendations for filter brand, and oil weight?
2002 Freebie is offline   Reply With Quote
Old 01-03-2009, 07:08 PM   #5 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
K&N for the filter if they make one for your car
My Ride - 2002 Discovery II - Stock And Going To Stay That Way
LandyII is offline   Reply With Quote
Old 01-03-2009, 09:04 PM   #6 (permalink)
Deployed OIF
ArmyRover's Avatar
Not fram for the filter. For the oil look in the owners manual and follow the recommendations in there.
89 Jaguar XJ6
Old 01-05-2009, 01:41 PM   #7 (permalink)
Does anyone happen to know the correct wrench size for the oil filter on th 2.5? Thanks in advance.
Brake change 97 vs 00 YellowFever Range Rover P38, Mk III and Range Rover Sport 3 04-28-2008 06:22 AM
Transmission fluid change theories Disco Truck Discovery Series I 3 03-09-2007 06:11 AM
PS Fluid Change wimp Discovery Series II 3 03-07-2007 01:30 PM
engine change 2.5 log burner Series Land Rovers 3 04-25-2006 02:20 PM
Oil Change Funrover The Lounge 2 03-25-2006 04:32 PM
