» Sponsors
» Sponsors
Old 02-10-2009, 12:52 PM   #1 (permalink)
Default Engine specs on the Freelander
Wanted to know info on the freelander motor. What other vehiciles was it found in ?
R390 is offline   Reply With Quote
Old 02-10-2009, 03:30 PM   #2 (permalink)
The NAS spec freelander engine is 2.5v6 24 valve fuel injected, water cooled engine.
compression ratio is 10.5:1, bhp is177 at 6500 rpm. tourque is also 177ftllbs @4000
It has a seimens engine management system with air assisted multi point fuel injection.
It is a 90 degree v6 with the front bank being cylinders 1 3 and 5, the right bank or bank 2 is the rear head an is cylnders 2,4, and 6,
What specs or info are you looking for? also to my knowledge this nas spec engine is only installed in freelander and is not shared with any other vehicles
LANDROVERFUN is offline   Reply With Quote
Old 02-19-2009, 11:29 AM   #3 (permalink)
what other rovers share the engine with this thing ?
Old 02-19-2009, 12:33 PM   #4 (permalink)
Deployed OIF
ArmyRover's Avatar
The freelander motor thankfully was only used in the freelander.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 03-10-2009, 06:47 PM   #5 (permalink)
thanks for the 411 on this, reason for asking is trying to help someone get their free lander up and running again
Old 04-23-2009, 12:04 PM   #6 (permalink)
Life, love and Land Rovers
Blippie's Avatar
Think the KV6 was also used in the Rover 75 saloon car, and possibly the MG version as well.
Cheers
Blippie
Blippie is offline   Reply With Quote
Old 05-28-2009, 11:39 PM   #7 (permalink)
If performance tuning is your thing then this is the best lump to play with as it is found in the MG ZS. It has one of the most fantastic engine management systems ever developed that gives the engine fantatsic tunability.
___________________
Great Fabric Repair Kit
khooper is offline   Reply With Quote
Old 05-30-2009, 12:46 AM   #8 (permalink)
Handrover
Default Freelander Engine 2.5L V6 Manual
Where can one find a shop manual? They are as easy to find as "hen's teeth!
sibosf is offline   Reply With Quote
Old 05-30-2009, 08:01 AM   #9 (permalink)
KevinNY's Avatar
They are commonly found on cheap used car lots or junkyards.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
wanted freelander engine or engine parts auggy11 Land Rover Parts and Vehicles Wanted 0 01-12-2009 09:33 AM
Gasoline Otto Engine No start/Misfire Diag Principles. Elemental Tech & DIY 3 07-05-2008 06:42 PM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 11:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 08:53 AM
