2 days ago i got the SES light. the code revealed evap system leak (large). could it be just the gas cap the needs to be replaced or is it anything else. has anyone run into the same issue before. any help is appreciated
thank you |
need to do an evap test with testbook. after they clear the code and perform an evap test via test book the system will detect a leak or not. if there is a leak then you need to fill the system with smoke from a smoke machine and check for leaks.
| Thread Tools | |
| Display Modes | |
| [All] Pre 96 OBD1 Fault Codes | TerryS | Tech & DIY | 0 | 01-26-2007 07:00 AM |
| obd two codes | Rovin4life | Discovery Series I | 4 | 12-25-2006 09:16 AM |
| 0BD 2 code list | Rovin4life | Range Rover P38, Mk III and Range Rover Sport | 1 | 12-19-2006 06:43 PM |
| P38 ..Non-Starter!! | Fozzy | Range Rover P38, Mk III and Range Rover Sport | 25 | 04-12-2006 03:50 AM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 01:18 PM |
